Hello all,
the front seatbelts in my 87 Olds have a problem. The pass side is stuck and will not move. The driver side is stuck but will release if you remove the big torx bolt,let it recoil down, and then bring it back up.
So can I repair the seatbelts or do I need replacement front seatbelts.GM says the belts are not made anymore. Since our cars ar of the same year and mfr do you all have any recommendations(other than the junk yards) to get a new belt.
Thanks all,
Edward
Thanks all,
Edward
