Looking for a steel posi cap for a stock differential. Would only need the drivers side to add alot of strength to the unit. I am not sure if custom fitting is necessary to make it work.
Maybe a steel cover that would contact the cap would be another solution. The covers on the market are torqued to only 5 foot lbs against the cap.When the cover gets heated and expands, I think the setup becomes questionable.
Jeff
Jeff
