When regrinding a cam, you usually cant change the duration by more than 4 degrees, nor the lobe separation angle by more than two or three degrees. The hardening isn't usually deep enough to go any more.
Also, I only use Comp Cams for my engines, as they have the most lobe profiles available, and along with Bullet, seem to be the most precision companies, with the most choices of ramp rates available.
That statement comes from owning a cam analyzer for about 25 years. It measures to .1 degree and .0001 lift.
I can measure any duration at any lift, graph the lift curve, measure the area under the curve, and overlay the graphs.
SOME of the smaller companies still grind from masters, rather than CNC machines, and they tend to have less aggressive, older design lobes, that will make less power due to less "area under the curve."
Look at the duration at .050, and again at .200. A longer duration at .200, for the same .050 has more top end, and a wider power band, but still comes on the cam at the same RPM.
Ask if your company can furnish a lift/duration chart listing the: SAE duration (.006").050 and .200 durations before you buy.
Comp Cams has a lobe catalogue, if you are at all serious about making power, get one.
A FEW companies will give you the info, others won't, published, or not.
If they don't have it, or won't provide it, I don't buy from them.
I have analyzed nearly every cam that has been provided me to put in customers engines since I bought the analyzer. What an eye opener! A LOT of cams aren't what they are advertised!
The difference in price isn't worth the difference in performance to ME!
TIMINATOR
