I guess my car had the open rear originally? This is what happened driving and rear end completely locked up screech to a stop ! Got car home and after opening it up I found that one of the spider gears fell apart and messed it it all up carrier, spiders and it took a couple of small chunks out of ring gear also. I machined the ring gear as smooth as I could where it was chipped at and just installed exact fit replacement to what was in there already; new carrier, spiders, pin, bearings, etc. and everything is good except as I back off throttle I get funky vibration which I'm sure is from the damage to ring gear, livable but I want it right.
So I will have to replace the ring and pinion gears so I say well , I figure all the labor go ahead and go all the way new limited slip,etc. I am wanting to get a realistic idea for my rebuild. Questions like, Will my stock axles still work? Good source for parts vendor on TB.COM? Ratio specs that might be changed or stay the same?
Not racing car might have fun at the track few times a year for fun, nice occassional ride, stuff like that.
I hope this helps clarify what Im trying to do. Thanks
