I have about 1,000 miles on the rebuild. The heat range of the plugs is correct. I just did a leakdown test and all cylinders were at about 10%.
I usually run alcohol injection.
All of the plugs looked really rich and had some dark deposits that were wet looking.
My egts are always 1700 to 1850 F. This is the same whether I run alky or race gas and no alky.
ZERO knock always on Direct Scan and the audible detector is quiet.
I have 3 egt gauges, so this is not the problem. The probe is mounted a few inches below the turbo.
I've always heard that egts should be around 1550. I didn't see those #'s before or after the rebuild.
I would expect a cleaner plug with those high egts.
Any ideas on why the egts are so high?
Thanks.
Thanks.
