I have a 79 LeSabre with an am/fm radio that does not work. There is a three wire plug that goes into the rear of the radio with a yellow, black and brown wire. I think the yellow is power, the black is ground and the brown is for the light inside the dial.
When I plugged the plug in I got nothing. How do I check to see if the radio is getting power? I connected a yellow wire directly from the fuse panel to the yellow plug wire and still got nothing. Got a radio from the jy and nothing. Can one of you wizzards give me some suggestions?
TIA
Roger
TIA
Roger
