sorry in advance if this is long. 2 cars 2 different problems. car 1-87 gn, buddies car. he had a new racetronix pump from eric marshall installed about two weeks ago. i was out with him today and he said car didnt feel right. i hooked my fp gauge up. gauge read 65 psi at idle. i tried adjusting pressure down, would NOT go down. run screw all the way in pump will go over 100 psi, but again will not go under 65 psi. removing/installing vacuum hose has no effect on pressure. also, when you shut the car off, pressure immediately drops to 30 psi and holds. i blew shop air through return line and tried another regulator with no change. ideas? car 2- my car. same pump from same vendor, in the car about 6 months. i started noticing a month ago a flutter in my fp gauge at idle (hood mounted gauge) slight flutter about 2 psi. noticed the other day when the car goes into boost, it will go to 73 psi, about where it should be, then start fluttering wildly from 60 to 80 psi (back and forth, continuously)! again, ideas please. Tia..
