I had an ATR single shot (3") with no cat on my car. Car has a decent cam in it, no cat on it, headers etc., etc., WOT on the car, loved the sound. Cruising around I got to where I hated the noise.
I took one of our mufflers we have custom built for some exhaust we build for EVO's and decided to do some custom work on the car. I ended up building a new system from the downpipe all the way out the back on the car. I did this for two reasons, one I saved a good 10 pounds of weight using our SS tubing and muffler, the other is the ATR with the rear suspenion work and lowering on the car hit and rattled. It never did with the car stock as a side note.
Anyway, while doing it I put the new muffler where the cat use to be. Figured if it didn't work out I'd pull it and move it.
HOLY ****! The car is so much quieter with the muffler with the muffler where the cat was than when it is closer to the back of the car.
You might want to try moving the muffler you have to that location before you spend a bunch more money on the exhaust system. It will probably be an easy move.
I have now done this on a couple of other cars and have had the exact same results. No other changes were done on the other cars, just took the same muffler and moved it closer to the front where the cats were on those too. HUGE difference in sound levels.
I am actually so happy with the sound level of my Buick and the weight of the system I considered having them bent and selling them. The clearance with the full H&R rear suspension is perfect too, even with the car dropped 1".
David Buschur
www.buschurracing.com
