I have all of the bolts out that I found that are on brackets. I am not sure how you are supposed to get a wrench in to remove the oil return line!? I was searching around and can not find any prior threads that cover this all the way through. Some one said to leave the retun line hooked up and pry the turbo out!? Not comfortable doing this untill I get confamation that this is the proper way. I did not see any thing holding the intake pipe in place and I cannot see where the oil return line gose. Any help would be great all I want to do is pull my injectors!
