Question for Bob
Scott87
Conscious guided
I just bought an extender extreme from full throttle. I wanted to clarify and see if this will work with what I plan to use it with.
Chip id
BSO34COFA
Will this chip communicate with the power logger I plan to install it with? Seeing as the second digit comes up for communicating with stock.
The second question has to do with the wastegate designation of 4. Since I am not using the stock wastegate and actuator will this be a problem?
Thanks in advance.
The datastream only has to do with a Scanmaster connected to the ALDL plug. It will not affect anything with the Powerlogger.
On the wastegate, since you are controlling the boost yourself, then there is no problem.
The chip datastream does not affect the powerlogger.
Your wastegate hardware bypasses the ECM completely, so you are good to go there also.
Bob
Figured as much... Seen different designations for that classification causing me to question it..
Thanks for the responses ...
