Champion's spec sheet for GN1 heads with Scorpion rockers says 8.850 pushrods will be a good starting point, but you really need to buy a checking pushrod, set up the valves on one cylinder with checking springs, and make sure the rockers are moving across the valves in the center of the stem. Mark the stems with a sharpie or Dychem blueing. Deck height, head gasket thickness, and any material removed from the heads will affect valve train geometry with those rockers.
