Terrance P. Perryman
- Dec 28, 2012
Is anyone running a simular setup like mines???? 109 block with Champion GN1 14 bolt aluminum heads,Fell to 9441pt head gaskets, T&D 1.65 roller rocker arms, Morrel Roller Lifters with 8.250 Trend Pushrods. If so what length Push rod are you using and how is the valve train noise? I checked my preload with a Comp Cams Push rod length checker. I just want to make sure that I'm close or need to Chang something. Thanks...
