Ok, here goes. My TTA has had on ongoing hard start/no start problem, and seems to be getting worse, especially after a heat soak. This is what I've done so far:
1) Swapped battery & altenator with known good ones (no codes ever present)
2) Checked fuel press with 2 different guages, prime ok
3) Swapped ECM, prom, ign. module, coil. Wires & plugs are new.
4) Checked battery cables & cleaned grounds on back intake studs & firewall, replaced starter w/ mini high torque starter
5) Checked spark w/ spark tester-ok, checked inj. pulse w/ noid light while problem happening, found light pulsing but very weak, and the longer cranked the dimmer the light???
There is probably lots of other stuff I've checked but can't remember now (my brain is fried). The car has 39K miles, and has now signs of a salvage or major accident. Car has 36lbs inj's (problem was happening w/stk. inj's too)...also swapped MAF sensor & verified TPS setting & voltages.
Any ideas, or has someone had this problem before??
