This is a little cross posting from some of the other forums I'm on. I've owned the car since Dec. 2002, rebuilt/modded at 135K I'm over 150K miles now. I like to get the information out there and documented because too many people in our community just do their stuff without a whole lot of info on what went on. It goes like:
"Picture of my car before."
"Magic happens!" *Virgin sacrifice not included*
"Picture of my car after with 500 hp more!"
So here's a good look at what I went through to get where I am today.
What the car has now:
Factory Options:
GU6 & G80, AKA 3.42's and a posi. Something not commonly found in V6's outside the W68/Y87 packaged cars.
Exterior Modifications:
Speedline MIstral 6's 17" x 9.5"
Kumho Ecsta 275 x 40 x 17
8000K HID low beams.
8000K HID fog lights.
60LED Switchback DRL/Turn Signals.
Debadged, trim delete and rear filler panel is now devoid of the firebird name and logo.
Interior Modifications:
Corbeau CR1 race seats
PLX Wideband gauge in central AC vent
Weight Reduction
Performance:
Whisper Lid
Intense S1X NA Cam: 212º/216º .556"/.546" 113º LSA (With 1.7 ratio rockers)
Yella Terra 1.7 Platinum series roller rockers
PAC 130# springs
60°Inclusive ported heads and intake
10:1 Compression
LS6 Fuel Injectors w/ FAST spacers
Manton Pushrods
LS7 lifters
Fabricated Valve Covers
Force Fed Fabs Longtube Headers
3" Spun Metallic Cat
3" Electric cutout
3" dual out turbo muffler (Dynomax)
Suspension/Chassis:
Front:
BMR 32mm Solid swaybar + Poly endlinks/bushings
PARacing Tubular K-member RR
HAL QA1 12-way coilovers
Rear:
LS1 19mm swaybar + Poly endlinks/bushings
UMI Performance LCA's
UMI Performance Adjustable Torque Arm
HAL QA1 12-way shocks w/ WS6 rear springs
Drivetrain:
Aluminum Driveshaft
Yank Torque Arm Relocation Cross member
TCI Super Street Fighter 3800 stall w/ 2.1 str
4L60E built by Richard at Precision Transmissions in Amarillo, TX
Hayden 1405 trans cooler
Electronics:
HPTuners
PLX Wideband
CDT Door Speakers: CL-61CV.2
CDT Sail Panel Subwoofers: HD-6M DVC
To-Do List:
Install ram air hood, build air box.
Break into 13's NA.
Collect parts pile for T-56 build. *Clutch kit is all that remains*
Afterwards, build parts pile for boost build.
Factory Options:
Weight Reduction
Performance:
Whisper Lid
PAC 130# springs
10:1 Compression
Manton Pushrods
LS7 lifters
3" Electric cutout
Suspension/Chassis:
Front:
Rear:
Drivetrain:
Aluminum Driveshaft
Electronics:
HPTuners
PLX Wideband
To-Do List:
Break into 13's NA.
