when my car was running, it would idle high about 1800-2000 RPM, it would stall in gear unless i gave it very very little gas until i got up to speed, and it wouldnt build boost, the stock boost guage said about 5 PSI, but an aftermarket boost guage would only go up to 0 vacuum when i revved it up, you can hear the turbo whine, and the wastegate rod was adjusted for maximum boost. it has a chip from poston, 42.5 injectors, warlboro 340-hotwired, T33C turbo, adjustable FPR, and 160 degree Tstat. it is an 84. if anyone could give me any advise i would greatly appreciate it, i would really like to get this car running for spring. thank you
