- Jun 18, 2001
I thought I would post some pics of my Ttype which has been an on going 18 year project that is still a work in progress. It finally made its way to the dragstirip and on to a road course recently with some success . I am having a blast with this car this year and finally enjoying it more than working on it and for some reason this is one of those cars that has fought me every step of the way!
I've had this car since 2005. I did a complete frame off resto which I finished in 2011 then traded the car in 2013 and got it back in 2018 exactly like it was when it left and then proceeded to completely re-do the entire cars suspension, motor and drivetrain and this year I am finally finishing it and getting the car sorted out.
Deets:
Car is pretty well optioned and rare Canadian Import ehh! It was a mess when I found it as a roller but super clean and still wears all of its original sheetmetal. I preserved the car's originality as much as possible with the build, its really quite stock appearing other than the frame is 5.5" off the ground. All options work including AC and car even has all its factory jute padding weighing in at 3700# with driver and full tank of gas.
Motor is an mint off-center 0012 Stage 2 block with 4340 3.625 crank Oliver 6" Billet rods, J&E pistons
GN1R heads ported stock intake ported stock TB.
TA headers wtih 3 bolt PTE billet wheel 6768 3" THDP and 3" ATR crossflow exhaust
GN1 SLIC that gets quite toasty with this combo
Janis billet rollerized 200r4 Bradco TQ
Denny's 3.5" alum shaft with 1350 Ujoint and billet yokes
Stock 8.5" rear with 30 spline Mosers, and rebuilt/upgraded GM carrier
ECUGN with flex fuel on Corn
Racetronix 750l fuel system and fuel lines 120# injectors
Cooling is Champion radiator with twin spal fans with int oil and trans coolers and one external trans cooler and a power steering cooler I am in process of installing. The radiator is bad ass car is never over 175 even getting off the road course after a 20 minute session!
Front suspension is Ride Tech TruTurn UCA/LCA made to work with Viking DA coil overs 550# springs and RideTech 1.5" Musclebar front sway bar.
Rear Suspension HRparts UCA/LCA with UMI adj rear roll bar and UMI rear coilover conversion with Viking DA Coilovers with 125# springs (but going to 175)
Brakes: Baer 12" rear SS4+ and currently the 11" Baer SS4+ fronts but they are sending me parts to convert to 12" in front.
Wheels, early GTA two piece wheels I had machined and polished repainted they were originally grey GTA wheels and match the car. I had the rear cut apart and re-welded to deeper offset. I have 6 wheels total with Toyo R888Rs 245/255 for road/autox and a pair of Toyo 275/45 DR on the other two which work ridiculously well even on the street.
I built this car to do it all!. I showed it at BG this May. I drove to the drag strip a few weeks ago on a Wed night TT, and ran 10.75 and drove off the track and drove home. I ran the car exactly like the car is driven on the street, same gas in the tank (pump E85) and tires on the car. A week later I changed out the rear drag radials tighened up the coil overs and took it road racing! I have the NE Musclecar Challenge coming up this Thurs to Sat at Pitt-Race. This is road racing and auto-X event for 1987 and older American made cars with V8s and one V6 lol!
Deets:
