Bottom line is, get more O2 molecules in the cylinders. Volume flow isnt restricted to more rpm or more boost. If you can get more volume flow out of the heads/intake, then at boost for boost (same boost before and after), the improved heads, which are giving more volume flow than before because of their larger ports/valves, etc, will automatically provide more mass flow, or O2 molecules. Think of the intake runner volume. You have 200cc's of air at 20psi vs 150cc's of air at 20psi. The larger runner automatically has more mass flow because of the increased volume. Say under 20psi, there are 1 million o2 molecules in a given cc of intake runner, and this wont change no matter what size your heads are. Say you increase the size of the intake runner from 150cc's to 200 cc's. Now those molecules have somewhere else to go, so now you have 700,000 molecules per cc of intake runner. As a result, the boost, or pressure, or restriction has dropped, to say 16psi instead of 20. Crank the boost back up to 20, so now you're back to 1 million molecules per cc, but now you have a 200cc runner. At 20psi, you will have 50 more cc's of 1 million O2 molecules per cc, being pushed into the cylinder. The mass of air has increased, because the volume was increased. Now if you had never touched your heads/intake, the only way to increase the volume would be to increase rpm. Turning the boost up wouldnt do it. It would only increase the mass of air, not the volume. BUT, given the additional compression of the air, (higher boost) you would heat the charge up significantly, because now you're trying to squeeze 1.3 million o2 molecules into a given cc of runner volume. given the additional heat, the charge will be "thinner"..given the math you would think you have 1.3 million, but its more like say, 1.2. Add even more boost for another .3 million...but its not working. this time it only increased by 1.0 The next increment in boost yields another .5. It gets less and less efficient as you try to squeeze more air in through the same small intake runner as before. Thats what the compressor map will show. It will show that you can make say, 600hp at 38psi, and you can also make 600hp...on 23psi...with the same exact turbo. Which is better? Obviously the lower boost number. Much easier on parts and engines. Less octane requirement, less IC requirement, more timing (which = more power) etc. But the only way to tap into the efficient range of the turbo, is to tap into the efficiency range of cylinder heads. You'll need to open things way up and get those heads and intake to flow flow flow. The more power you can get out of an N/A engine, the greater the gains will be under boost. The rough formula for boosted power is boost divided by 14.1 + 1 times N/A power. 20psi/14.7+1= 2.36. This is your pressure ratio, which you will see on a compressor map. Multiply that ratio by your N/A power, and thats roughly what you'll end up with. I used this formula to find out that our engines, if the 275hp number was real (not the advertised power), then our engines would be making roughly 137hp in N/A form. Increase the boost on that stock engine to say 20psi. 2.36 x 137.5= 324.5hp. Now if we opened things up so that the engine makes 180hp in N/A form, then the power at 20psi would be- 2.36 x 180= 424.8hp. Same engine at say 15psi- 15/14.7+1 = 2.02 pressure ratio, which says 2.02 x 180= 363.6hp. So by increasing the power of the N/A motor by 42.5hp, we have an increase of 363.6 - 275= 88.6hp...all at the same stock boost level.
