T Terrance P. Perryman Member Joined Dec 28, 2012 Mar 13, 2017 #1 Is there an after market press fit rod available for a stock 3.8 engine. Thanks.
T tsm3089 Member Joined Nov 11, 2006 Mar 13, 2017 #2 molnar has a stock replacement rod with a 0.940 pin. I would check with them or one of the vendors to find out if it is press or bushed.
T Terrance P. Perryman Member Joined Dec 28, 2012 Mar 13, 2017 #3 I checked and it appears that no one makes a press fit rod only bushed.Thanks for the reply.
E earlbrown runs with scissors Joined May 26, 2001 Mar 14, 2017 #4 I guess you could hone out the pistons for a .945 pin and then hone the rod end to end up with a press fit. It'd be easier to just install the locks and be done with it though.
T Terrance P. Perryman Member Joined Dec 28, 2012 Mar 14, 2017 #5 Thanks Earl. I have Speedpro forged pistons and I was trying not to buy new pistons and rods.
E earlbrown runs with scissors Joined May 26, 2001 Mar 15, 2017 #6 If you get new pistons, you won't need new rods. And you can use those heavy pistons if you get a set of stock rods. No need to swap them both out.
