LT1ThirdGen
- Jul 2, 2005
Question for you Powermaster gurus.
Background: Just got my 87 GN back from a local shop after spring cleaning was done. Flushed everything, all fluids replaced, including brake flush/fluid. When I pulled the car into my garage and shut it down, I saw smoke coming from the drivers side of the hood. Popped it open and literally watched brake fluid drip out of the master cylinder, hit the manifold, and catch fire. Put it out without (hopefully) any damage. Upon inspection, I noticed that the master cylinder was filled damn-near to the top. I seem to remember that these units didn't get filled all the way up, so I pumped the brakes with the key off 10 times to depressurize the system, and took the reservoir cover off. The rubber gasket was soaked on top with brake fluid, so I assume it was overfilled and leaked out while I was driving. I siphoned out about 1/3 of the fluid from each reservoir and reinstalled the gasket and lid. Reservoirs are about half full now. Put the key in the ignition and fired it back up for a few seconds. Brake light stayed on. Shut it down and depressurized again, took off gasket and lid, and the reservoir on the passenger side had the same volume as when I closed it up, but the fluid looked milky as hell. I let it sit, and it returned to normal brake fluid color within ten minutes.
So, question: did I screw something up by pulling that fluid out? Should I put more back in, or am I in over my head jacking around with this POS Powermaster and just leave the damn thing alone and tow it back to the shop and let them deal with it?
Comments and advice would be greatly appreciated.
Thanks in advance.
Thanks in advance.
