What is the matter with the PM system? Is the master cylinder bad? or is the power assist not working properly. If master cylinder, then GM still sells a rebuild kit. A member on the board still sells motors and if you search, I posted a way to make an adapter to hook up to a brake pressure gauge to test you PM assist unit.
