I bought what I think is a 3-bar MAP sensor from GM today, part # 12223861 and matching pigtail 15305891. Even with my discount, they're over $150. These were to replace my "cheap" e-Bay ones.
Both the old and new ones just register completely wrong in PowerLogger, including the 2.0 version. I'm setting the config parameter to "3 Bar Sensor" but the values on the data screen make no sense. (ex. 4 PSI at idle, etc.) When I try to adjust the offset, I can do +/- .4999 (and it's a little tricky to enter values), but it doesn't seem to help.
Ex.
Offset: 0
MAP Sensor Volts: 1.424 (in the config screen)
MAF: 12.0 g/s
Boost: 8.5 PSI
TPS: 0.42
I have the sensor grounded to the body which might be the problem as well.
Ex.
Offset: 0
MAF: 12.0 g/s
Boost: 8.5 PSI
TPS: 0.42
