Neither turbo will make more power at low boost.
My daily driver saw zErO performance gains with the stock heads between a 44 and a 54.
I loved my 44 10x more than the 54, and at 20 psi it wasnt that quick...TILL i hit the sweet spot of 23-24 psi of boost and the 44 made the car fly.
20 PSI of boost with a larger turbo is a waste unless you have really good heads, then again, if you have race ported heads then a 54 will be too small......
I just went back and noticed you are going to try the 6152, I have that turbo on my blue limited (currently has the motor out) i purchased it broken.
The 61 with the champions and roller cam is going to be quite the street beast, off idle torque and lots of higher RPM horsepower..
I will let you know how she goes :biggrin:
Im going to start the boost at 20 and work it to 25 and get the timing set right with erics chip, My goal is 10.9 at 124...
BW
