U Unit73 New Member Joined May 14, 2004 Apr 14, 2005 #1 On the '83 T-Type, what would keep the power antenna from functioning? It always stays in the up position...is there a motor, or relay? Thanks!
R Red Regal T Senior Member Joined May 24, 2001 Apr 14, 2005 #2 83............87 same thing. Do a search. plenty of info. Also info on the turbo regal website. My guess, your antenna motor is toast.
T Turbo Brian What do I type here? Joined May 24, 2001 Apr 15, 2005 #3 It might be unplugged if it was running continuously with a broken plastic cable inside the mast. Check the plug in the passenger side rear of the engine compartment.
