ek02
- Jan 31, 2008
Heads are port matched to stock gaskets, fully ported valve bowls. Ferrea stainless valves (1.770 intakes). Heat passages have been filled with aluminum. Heads were surfaced before the last time they were run. New, never run valve springs and Kenne Bell retainers and locks. Springs are 104 PSI @ 1.740" installed height, 270 PSI @4.90 lift. Coil bind is 1.190. Guides have been cut with new Viton seals. Rocker stands are clearanced for T&D rockers. These heads were run for a short time on an N/A engine, then I freshened them up, but never ran them again. These heads are perfect for a flat tappet cam with .500 lift. I will only take PayPal. Price shipped in US in 2 boxes, $650.00. I can also deliver anywhere in South Florida. HEADS ARE SOLD.
