Hey guys, I went to PIR last night to try out my new combo before Turbo Thunder. This is the first time out at the track with my Buick (only had the car 7 months).
My best run was a - 12.46@109 with a 1.96 60 foot time
My 28X11.50 ET streets were spinning all the way into second gear. Also my o2 readings were in the 930's at the top end. After each run I would get a code 42 and 34 (Est circuit problem and MAF volts low). I think my code problems and high o2's are caused by some interferance with my translator + .
Hopefully I can get my problems worked out before Turbo Thunder ~ see you guys there !
