Pinout for LS1 Maf needed
Benched
I am locating a Translator + in the glove box, and I don't want to have 6 wires and 4 connectors running between the X-lator and the new maf.
Another question would be what are the pink, black, and yellow wires on the T+ as regarding their function.
I want to intercept the original maf wires right before the ECM, put a male connector on them, and take the other end of these wires and put a female connector going to the ECM. Before a smog check, I can remove the T+ from these connectors, join the the connectors, and reinstall the factory MAF.
You might want to PM TurboBob if the T+ didn't come with a wiring schematic.
LS1 maf
I can get an LS1 MAF from a friend....where do i get a translator with intructions and will one of these help the car??
"Samaurai" installation method
The T+ comes with a 6" adapter that will let you plug the LS1 MAF right into the stock wiring.
T+ wiring:
Pink - +12volts (either one)
Black - ground (either one)
Yellow - MAF signal INTO T+ (from MAF)
Green - MAF signal OUT of T+ (to ECM)
White - EST (spark signal) INTO T+ (from ECM)
Gray - EST (spark signal) OUT of T+ (to ignition module)
You can get some connectors by buying one MAF extension cable and cutting it in half.... :)
hth
TurboBob
where do i buy the translator and other
stuff needed if i have a 2002 ls1 maf off a trans am??
thanks
ramchargers has the stuff but i dont know what is needed?
thanks again
Samari method, that's funny.
Bob, can you confirm that at the ECM, C2 block, that A6 is power (MAF pink/black), B6 is signal (MAF gray/red), and that B4 is EST (CCCI point A -white)?
Thanks for the help.
