regal81455
- Oct 20, 2008
Good job meng very clean!
Did you modify the reservoir for separate returns or did it come like that?
I love the pedal feel over stock setup.
Where did you get the reservoir from?
Does it have any internal baffling?
Does the cap seal well?
My speedway motors rezzy leaks badly and had only one return.
Do you know what AN fittings you used on the pump and hydro boost?
Cool ,
Im going to flip my booster upside down and run the hoses from the bottom for a cleaner look. I think I will even be able to use straight fittings and no 90s Im going to try and mock it up this weekend if I can find some time.
Looks awesome.
Question. How long ago did you order that res?
I believe that was the old design. I'm pretty sure they went to the new design because people were having cavitation issues.
Mine has all 3 ports on the bottom.
It looks like the mounting pad is just screwed on to the booster so Im hoping I can just un screw it put a spacer on it and screw it back on upside down. I havent tried to remove the pad yet but if it just unscrews it shouldnt be a problem.
Sorry for the confusion. I didn't mean their design, maybe it's perfect with the baffle.I just got mine about 2 weeks or so ago. I hope they weren't having problems with them - I would think that Kelvin @ PSC would have mentioned this when I bought the tank. If there is an issue Im going to be really upset!
