Sal Lubrano
- Apr 26, 2002
I am currently using a translator ,extender extreme chip with alky. I am looking in to getting a plx wideband to monitor o2's. Once the wideband is installed a 6.1 TT chip would be next to keep the tune perfect. I understand the need for these upgrades but would like to understand where the extender chip falls short keeping the fueling correct.
Can someone correct me if I am understanding this incorrectly. As the car is idling and cruising in closed loop the blm's and int's change from 128 (base program) to meet 14.7:1 AFr. At about 20% TPS , Power enrichment mode starts. It uses BLm 15 to calculate the difference from base programing in Pe. While in PE the computer is using air temp, maf (extender extreme), rpm, load, coolant temp.
How far off can the AFR be if it is using the MAF at WOT? Without the extra MAF reading (max 255 g ) I can see how fueling becomes an issue. You basically, run out of programed fueling so you turn the fuel pressure up but the chip changes blm 15 so you basically get no where. So, the chip manufactures reset the blm to 128 in PE. Then use fuel pressure to control fueling. But this is not the case with the extender it can measure the amount of air. So, how far off could the o2's actually be?
I also see the problem with the alcohol adding fuel. The computer can not control this fueling so there is too much fuel going in to the engine. I guess the chip makers remove fuel when using alcohol but alcohol has a different stoichiometric afr than gasolines.
Can some please explain to me why I can benefit from the 6.1 and plx? Also, does the 6.1 chip need the translator since it uses the wideband?
