FastRegalWE2
Wish I had another Buick!
- Jan 10, 2004
Im done with this car, everything is getting parted out
will sell engine complete (turn key) or as a long block
-.040 over 109 diamond pistons and rings, K1 rods, cleveite bearings, eagle crank, JW flexplate, BHJ balancer (nuetral balance). RJC girdle, decked .020, GN1 14 bolt heads (decked .008) with pedestal mount Scorpion 1:55 roller rockers. Ported stock lower intake, heads ported to match intake. ARP head and main studs. 215/220 roller cam, Comp roller lifters. Rollmaster timing set, upgraded front timing cover with oil passages drilled. 2200 street miles, no track passes-$4500 will make deal with to add injectors, upper plenum etc.
-TCI th400, JW ultrabell, full manual reverse valvebody. $1100 -100 street miles, no track passes. Engine was assembled by Red of Eastern Virginia Turbo Buicks.
-PTC 9" 3600 stall $450
-Upgraded front yoke for th400 Forgot brand but can get it, was ($100+ new)- $75 new
-th400 poly trans mount for stock xmember- $75 new
-detent plate for factory shifter and th400 $20 new
-shifter applique for RMVB $10 new
-Turbonetics T70 P Trim, polished comp housing, JH2000 black .85 exh housing 2200 miles, no track passes $750 PENDING SALE
-83# inj- $250
-Champion billet fuel rails for stock style FPR $200
-Accufab AFPR $50
-precision 70mm upper plenum $150
-precision 70mm TB $175
-Razors Progressive alky kit- $450
-3.5" aluminum driveshaft $250
-FAST B2B with brnad new WB02 $1250
-ATR 3" external DP, JH coated but peeling near WG $250
-Turbonetics Evolution WG, multiple springs- $200
-ATR SS headers, JH coated but peeling in some places $600
-Complete rebuild front end kit, all urethane bushings, new ball joints, tie rods etc PST components-- make offer
-PTE front mount I/C tube and fin, $550
-4" Big Mouth CAI $150
-RJC billet pullies- complete set $400
-HR parts poly drivers side engine mount $50
-ATR test pipe w/dump $40
-ATR driveshaft safety loop $50
-4 Bilstein shocks- $325 2200 miles
-4 springs front/rear $200 2200 miles
-Weld Pro Stars 15x7 front, 15x8 rears, 275/60/15 MT Drag radials and 2 new front tires, forget the brand 2200 miles $750
-Ramchargers dual fans with PnP harness $75
-Accell coil and GM CCCi- $200 2200 miles
-have complete -6 AN trans cooler lines from radiator to aux trans cooler and trans $100
-Complete -8 AN fuel feed line with y-block at tank for dual in tank pumps $200
-Dual intank Walbros 255 lph with hangar $200
-braided SS turbo oil feed and drain lines $75
-aluminum core support, cleaned painted black and uncut $250
-8.5" POSI GN rear, stock 3:42 carrier ring and pinion, TA perf girdle, Moser 28-spline axles, S10 wheel cylinders, 4 large brake shoes, aluminum drums $1200
-Metco lower rear trailing arms $225 with weld on relocation brackets $225
-Metco adj upper rear control arms $225
-complete vacuum brake conversion $100
-F Body alum radiator $50
-HR PArts rear sway bar-$425
-All frame braces, underhood, front frame , rear seat $125
-aluminum bumper supports front and rear $75 each
All prices are less shipping, Pay Pal add 3% for their fees. I will start parting the car on the weekend of 14 Apr. Larger items will require a bit more time for shipping as I do not own a truck. Anything can be picked up at my home in Mustang, OK. I move in there on the 13th of Apr and will begin parting out the car then.
other items will be added later. Will also be selling the body of the car and interior.
pics and a short video on my cardomain page in my sig.
Jeff
-83# inj- $250
-Accufab AFPR $50
Jeff
