Vin code is 1G4AK4796EH496971. Line number 089571
RPO codes are...... from what I can figure out....
AM6 Seat,frt split,3pass.ctr arm rest
At6 Adjuster pass st bk. manual,recl
Au3 Lock control,side dr,elec
A01 window,tinted,all shaded,w/s
A31 window,power operated,side
A90 Lock control,rr compt lid, rem cont elec release aaaaa
BC3 ornamentation,intr,instrument panel,deluxe
BD1 ornamentation,exterior molding,rocker panel---delete
BMD ?????? No clue
BS1 Insulation,acoustical pkg
BV6 ornamentation, extr lock cylinder,painted
BV8 ornamentation,extr dr hand, lock cylinder
BX5 ornamentation, extr mldg,roof drip,painted
B24 ornamentation,extr mdg,side window reveals black
B33 covering,rear floor mats aux
B71 molding whl opening,colored
B72 ornamentation,extr mldg belt reveal,colored
B77 ornamentation,extr mldg w/s reveal,colored
B79 ornamentation,extr rear end
B81 molding b/s---delete
B89 ornamentation,extr mldg,rr window reveal
B93 ornamentation,extr mldg,dr edge guard
B94 ornamentation,extr emblem,body,var 1
CD4 wiper system windshield,pulse
C18 arm & blade,wsw
C49 defogger,rr window,electric
C60 hvac system, air conditioner frt man controls
C95 lamp,intr,roof,courtesy and dual reading
D3D ?????? No clue
D35 mirror o/s,lh rem cont,rh direct cont,painted
D64 mirror i/s,rh,sunshade,illum
D85 stripe,body side lower accent
E5Z speedo adapter delete (analog gage cluster only)
E7K ?????? No clue
FE2 suspension system,ride handling
FFL ?????? No clue
GQ1 axle,std ratio
GU6 axle rear, 3.42 ratio
G87 ring gear,8.50 inch
J42 brake system,pwr,frt disc,rr drum,aluminum
K15 lines,fuel vapor return
K22 generator,94 amp
K34 cruise control,automatic,electronic
LM9 engine,gas, 6 cyl,3.8l,mfi,v6,turbo
MW9 transmission,auto 4 spd,thm 200,conv clutch
MX0 mechandised,trans,auto provisions,o/d
NA5 emission system,federal,tier o
NB1 emission system,closed loop
NK1 ?????? No clue
NP5 steering wheel,leather wrapped
NQ5 cap,strg whl horn deluxe
N33 steering column,tilt type
N90 wheel, 15x7,aluminum cast, 4.75 inch bolt circle
QYH tire all,p215/65r15/n wol r/pe sttl hwy
TL6 grille black
TL8 ornamentation,extr mldg hood,(3.8 sft turbo)
TT5 headlamps,tungsten hologen high beam
T47 hood turbo
T83 headlamps,dr,special
T93 lamp,tail & stop,special
UA1 heavy duty battery
UA6 theft deterent sys
UQ1 radio provisions, for stereo
US7 antenna,power,painted radio
UU6 radio,am/fm stero,seek/scan auto rev cass
UW4 speaker system,6 dual frt dash mtd f/d,dual
U52 cluster inst,electronic
VA2 radiator support steel
VD6 bumper provisions,frt, aluminum
VD7 bumper provisions,rr,aluminum
VK3 license plate,frt mounting pkg
V73 ?????? No clue
WA8 ?????? No clue
W11 t-type package
YT9 ?????? No clue
59L ?????? No clue
59U primary color,exterior orange met (92)
6CU ?????? No clue
65A stripe color,accent,two tone,lt auburn/dk claret
67E trim combination,cloth,lt camel (e) (91)
67I interior trim,lt camel (91)
679 seat belt,color,lt camel (91)
7CU ?????? No clue
8PZ ?????? No clue
9PZ ?????? No clue
Bottom of tag says DIS LAC WA- 8509 8509
Not sure what that stuff is. Figured someone may want some of this info.
