Just like it asks,
What is the limit of TQ/HP? When will I get close to burning it up in overdrive?
This Question pertains to my LT-1 383 powered Rx-7 with the 200 4r. It is 3150 lbs w/driver
As of the last time as the track I trapped 123.6 MPH.(450 hp at the wheels?)On that run i was running a small amount of nitrous(125 shot) not shifting to O.D. I stayed in third because the trans was a stock Monte SS and I was worried about the Overdrive. I was hitting 7k rpm at about 1200 ft so i think shifting to overdrive will help me some.
Now it is being rebuilt with three stock type frictions in the overdrive (this is the way my G.N. was done)
Also do I need to remove some of the springs in the direct clutch spring retainer?(these are for piston return?)
Thanks in Advance.
Thanks in Advance.
