Opinions please
belsie
I am running a stock intake & plenum w/ RJC plate, my question is since I am full E-85 could I live w/out the plate as I'm thinking it must restrict overall air flow as it does what it is designed to do???? Would a modified plenum or aftermarket be a better way to go? Just throwing this out for feedback..............Happy New Year
At a certain point, the plate becomes a restriction.
The only way to tell is drive it down the track, pull the plate, drive it down the track again. If the MPH goes up, it's in the way. If not, put it back in.
Richard Clark performed several flow tests with RJC plates. You might want to look it up. Seem to recall that they were not a restriction, but I don't recall what flow levels were used in the test.
If you're really worried about small holes causing a restriction, look inside the intercooler core!!!!
Those little bitty flues HAVE to be a MAJOR cork!!!!!
(that was sarcasm, BTW :) )
Now I want to measure the flow area of a PP as compared to a bored out throttlebody.....
