Would like to make and install my own diy alcohol injection system. I would like to run 11's on pump gas(94). Do you recomend using 1 line from the pump to 1 nozzle or.... take the 1 line from the pump and tee into it with a Y fitting to make 2 lines and set up 2 nozzles in the up-pipe for more spray and better atomization for the 11's. Which is recommended. THANKS in advance.
