Is it normal to have some wear on the pump housing after breaking in a new pump etc?
Mine was leaking around the gasket, so I pulled it to make sure it hadn't toasted itself. It has some new wear on the plate (I flat sanded it smooth before assembly) but not too bad. I checked the clearance at .002" dry before assembly. Packed it with moly engine lube and primed with a drill.
Oil pressure was a good 80 psi over 1500 during break-in, and only dropped to about 56 psi at 800 idle after 30+ min of break-in.
Stock volume pump btw.
I think I'm going to change gaskets and reinstall it to see if it still leaks...
