what would cause this? NEW ENGINE!
Too much bearing clearances in motor
Oil pump not clearanced correctly.
how do u adjust the clearance? I put my pump back together on my car and I did not have this problem. My dads had a high volume in it before but the new cover did not have pin holes drilled in it. So I put stock gears back in it.
thanks for your help. I am going to order a booster plate see how that works.
