Oil pump pick up tube.
carolinaturbo
Is the oil pump pick up tube the same for 20 bolt pan as a 14 bolt. Or same as hot air oil pan to ic oil pan? My hot air pick up is bent and doing conversion to ic looking a pick up. I am still running the hot air block so that is the pick up i need I think. Thanks in advance.
