russgoodman
- Jul 15, 2006
So I'm basically trying to figure out exactly what I have. I bought the car with swapped wheel studs all around (7/16). Put new rotors on the front so they are correct metric threads now. I've just been dealing with the rears being mismatched until I broke 3 of them off trying to remove my welds with slicks last week. Got longer than stock replacement studs for the rear in the correct metric thread but the knurl was way too small. So now I'm curious if these are stock axles drilled out for these bigger studs or aftermarket. To make things worse, each wheel stud is tack welded on. I've got some studs now that fit with slight modification but they are shorter than I'd like, but I think I can live with that. So have a look at the pic and tell me what axle I have. Thanks!
