I got a set of 4 15x8.5 Vector wheels, and one has an odd mounting flange on the back side. Everything else looks the same. The wheel on the left is like all the others, the wheel on the right has a recessed mouning flange.
(the brown center is recessed about a 1/4 inch into the wheel)
I was told that they came off of a '78 El Camino. I've never see a wheel with a mounting surface like this. What is it for? I'm afraid if I try to use it I wont be able to get it tight without damaging the wheel or the hub. Does it require some kind of spacer? Anybody else using a wheel with this kind of mounting flange?
