C chubba Member Joined Jan 14, 2011 Jul 7, 2012 #1 i have a heated o2 sensor with 3 wires in and out want to install non heated singel wire wich is the right one going out? thanks for the help
S SHADOWII Well-Known Member Joined May 12, 2004 Jul 8, 2012 #2 typically the heated unit responds better/quicker to changes then the single. It would be the single connector w/the light green boot. if you do not have one for some reason, you can go on casperselectronics.com and get one.
