b4black Well-Known Member Joined May 24, 2001 Aug 27, 2003 #1 I have an old cast iron manifold that I want to add a oxygen sensor to. It already has a boss. What is the drill and tap size I need for a stock oxygen sensor? Any issue with drill and tapping cast iron? Thanks!
K KendallF Blah blah blah Joined May 23, 2001 Aug 27, 2003 #2 18x1.5mm..just go slow and use some tap fluid or oil.
C ChrisCairns Senior Member Joined May 24, 2001 Aug 27, 2003 #3 I measured an 18mm tap I have. Then used my handy dandy drill/tap chart and it looks like the 21/32 drill bit should do nicely for the hole. (First drill a test hole into some junk stock and tap it just to make sure )
b4black Well-Known Member Joined May 24, 2001 Aug 27, 2003 #4 Thanks! Just what I needed. I'll be off the hardware store tomorrow. No more cracked headers for me.
