Here's my car's mods. It's getting finished at the machine shop and then dyno tuned and then she'll be home. Can I grab a high ten with this combo. I've owned this car for almost a year and have been redoing it and just dropping DOLLAR after DOLLAR into it. This will be my first time with it and I can enjoy it. My goal is high ten. I know your going to say you need a bigger turbo and it will be on the way once I FINALLY get my car back and enjoy and and pay off my mechanic.Rebuilt engine with 40 Bore with Diamond Pistons, Eagle Shaft basically everything I could do to sure up the engine and machine shop it and the Dyno Tune is completed.
TE60 Turbo Garret Housing
Front Mount GN1 Extreme Intercooler
Alky Kit
Shift Recalibration Kit
3000 Stall Converter
Ported Intake Manifold
Rebuilt Tranny
Eaton Posi Rear
60 LB Injectors
Duel Walboros 255
70MM Plenum
70MM Throttle Body
Champion Iron Heads
CAI
Cut Outs
LT1 Maf
Gen 2 Maf Trans
3 Inch Up Pipe
Turbo Tweak Alky chip
Rear Sway Bar
3 inch Poston Down Pipe
Pypes Catback
Poston Headers Ceramic Coated
Poly Urathane Body Bushings Kit
Rear Seat Brace Kit
Frame Brace Kit
Hood Brace Kit
Front Connecting Brace Kit
Fuel Pump Wiring Upgrade
Remote Oiling System Upgrade
Underdrive Pulley set
High Rev Lifters, Springs etc.
Gn 212 Cam
Upgraded Alternator
Accufab Adjustable Fuel Regulator
Fuel Rail Feed Line
H&R Parts Poly Motor Mounts
H&R Parts Poly Trans Mount
Mickey Thompson Drags
New Gas Tank
Upgraded Ignition and Coil Pack
Weld Rims
Scan Master
Aftermarket Gauges All Around
Alky Kit
Rebuilt Tranny
Eaton Posi Rear
60 LB Injectors
Duel Walboros 255
70MM Plenum
70MM Throttle Body
Champion Iron Heads
CAI
Cut Outs
LT1 Maf
Gen 2 Maf Trans
3 Inch Up Pipe
Rear Sway Bar
Pypes Catback
Rear Seat Brace Kit
Frame Brace Kit
Hood Brace Kit
Gn 212 Cam
Upgraded Alternator
Fuel Rail Feed Line
New Gas Tank
Weld Rims
Scan Master
