I just had a virgin BRF 2004R rebuilt by a local trans guru that has
a good rep on building the 2004R's. I also installed a new 3000 stall converter. A couple of questions. Taking off at light
throttle, will the 3000 stall converter mask the 1-2 shift? I can feel one shift at 16 MPH, which is 3rd gear, and 4th gear at 35 MPH. Then lock up at 45 MPH. If you get on it, it is definitely in 1st gear and shifts to 2nd just like it should. Is this normal?
Also, should it shift bang hard when you shift manually from 1st
to 2nd at light throttle?
Thanks for any help.
Dan
Dan
