Driving around the other night...noticed the brake lights werent working, parking lights were on, but step on the brakes, nothing.....figured it was the fuse. turned the car off, checked the fuse, it was fine. turned the car back on and they are working again. I've been reading up on the forum and saw something where the turn signal lever may be a culpret, and to do a bypass, cut the white wire from the steering column and jump it to the dash harness. before I do any cutting, I wanted to check to see if there is anything I am missing or do first. I'd rather not cut the wire but will do so as a last resort. Thanks for any input.
