84BuickGNYorkPA
Daily Driving Buick V-6 Turbo's 1979 - Present
- Jul 5, 2005
Well the adventure continues with the car. Going down the expressway last Saturday and the TR6 throws a code 16 (loss cam signal) but the car is still running good and next thing I know the idiot light is on for the oil pressure, I look down at the gage and it's at 0 psi, it takes about 2 seconds and I turn the key off as the engine was still running good. So I get it off the highway and rent a trailer from Uhaul and get it home and let it sit until today. After work I pulled the cam sensor and it looks good, but for good measure I drive the spring pin out to make sure it didn't shear off inside and sure enough it comes out in one piece. Next I put the socket on the crank and turn the motor over and verify that the rocker arm is moving by looking in the oil fill hole. Next I hook the drill up to the primer tool and have my brother watch the oil pressure gage, and the car has oil pressure?? So I did find a video on you tube where the pump shaft spins inside the drive gear of the pump, here is a link, not sure what else to look for.
Any ideas?
Chuck
Chuck
