Need to sell!!!!
Kid Turbine
I need this stuff gone!!!!!!!! get the pm's going!!!!
Prices as follows:
stock injectors 50.00
8- 83lb injectors 270.00
Direct scan 150.00 obo
TT chip 85.00
Stock ship 45.00
DynoTech stage 5 chip 45.00
stock 109 engine ( block,oil pan, rods, crank, pistons, heads, valve covers) 1200.00
stock 200r4 trans 500.00
PTC 3200 convertor with 500 miles new 550.00 but take 350.00
TT chip info
TT chip 85.00
spec sheet
86/87 turbo buick
street chip pump gas
msd 50 injectors
93-94 octane
cpt-61 stage 5
fmic
ptc 3200 convertor
stock heads with lt1 springs
212/212 comp cams
on the chip
v5.6 #3583
50lb. Street 93
20/18 degrees 17-20lbs of boost
call eric my customer number is 950
on the box is version 1.52 / 1.5 with serial number 895
More parts for sale
Also i have a 7th injector system that I was going to use it for a homemade alcohol injections system.
i have two stock intercoolers one with garrett sticker still on it and a air dam for stock intercooler.
Prices are
7th injector 90.00
stock intercooler 100.00
stock intercooler with garrett sticker 125.00
stock air dam for intercooler 50.00
Pics of items for sale!!!!
Here is some of the pics of items for sale!!!!
Trans, convertor, ds, and tt chip still on car!!!
more parts
OEM 87 GN ecm 100.00
Front mount intercooler mount brackets
stock intercooler fan 25.00
stock turbo that needs rebuild smoke at 10# 150.00
extra comp. housing, turbo wheel, exhaust housing, center section for stock 87 turbo. 100.00
OEM convertor 50.00
all item are best offer now!!!!!!!! :eek:
I believe its is about 1/2" but would have to measure to be sure, but comes with bolts to replace the stock ones.
Interested in converter.. which one is it? 10" LU? or 9.5 N/L.. i'm interested in an 9.5 N/L.
thanks
John
convertor
convertor
it is a 10" LU convertor from PTC!!!
intercooler cover
i still have the intercooler shroud!!! but mikestertwo asked for pic of the front of it will post today.
engine info:
it was running but I beleive it was trying to stack a bearing so I pulled the engine and rushed to finsh my race motor and put it in. its a complete motor except intake, flywheel, balancer, cam sensor, and crank sensor.
pics!!!
here are the pics of the front of the intercooler scoop and close pics of the 7th injector kit parts!!!!
