I haven't changed my plugs in several years since I don't drive the car much. 5 years ago I put in Autolite 103 racing plugs. I think the 103 is 2 heat ranges cooler than stock, but I can't remember for sure.
Info on my car. 86 gn, mild ported gn1 aluminum heads, 63 turbo, 55# injectors, alcohol injection, pump gas, JE race pistons, never run race gas, 125 mph at 22# boost (1/4 mile).
I have a few questions:
1. Is there an equivalent racing plug that is platinum or iridium for my use?
2. What Autolite plug would be one heat range cooler than the 103?
3. What plugs are you guys using that work well for 2 heat ranges cooler than stock, or for similar set ups as my car?
Thanks.
Thanks.
