I was running a power plate, no issues, at 24 psi with alky. Another member brought up a question and I never found a answer. The question was something like,,, If the lower manifold is seeing 24 psi, the valves all open the same amount, how does the power plate keep the rear cyliinders from leaning out? I can see how it would work on a naturally aspirated engine, but on a turbo application
I know many people use it and run fast
Just trying to understand.
Ross
I still picture this large chamber of pressurized air(or water). If the pressure is constant i just don't understand how "more" air will follow the roof of the plenum and into the rear cylinders. If thats the case wouldn't that mean there's more psi on the rear 2 cylinders? Trying to learn(it rainy here, can't get the buick or bike out)
Ross
Ok Rossy :tongue: have fun reading: Courtesy of RJC
Test #1
1987 GN stock long block, TE-44, 15 row stretched Stock location intercooler, 009 inj. 4500 ft. ele.
We made 3 baseline passes with the stock plenum at the maximum boost that we could run with the gas we were using. We were running VP C-16
The baseline runs were made at 26# of boost. This was the most boost we could run as we had 3-6 deg knock retard every run.
12.50 @ 108
12.55 @ 107
12.53 @ 107
We then installed the AD Power plate and made 4 more passes. Turning up the boost each pass because we had no knock.
12.49 @ 108 26# no knock
12.45 @ 109 27# no knock
12.40 @ 109 28# no knock
12.35 @ 109.8 29# no knock
12.40 @ 110 30# 8 deg knock. On the last pass we pushed a little through the lights so the clock started before we let off of the brake.
Since we first tested the plate we have tuned an additional three and a half tenths out of the E.T. The car now runs consistent 11.80@ 114. at the same elevation with no other changes
Our conclusion with real world testing confirmed what we were seeing on the flow bench. The Power plate maximized the airflow to all cylinders. Remember you can only run as much boost as the weakest cylinder will allow. This plate allowed us to run 4 more pounds of boost than with out it. Which in turn gave us almost 3 tenths reduction in E.T. and more than 3 MPH.
Test #2 I have tested it on my personal car, an 87 GN with extensive modifications. After installing the plate I made 4 passes they were all in the 10.60-10.65 range. This was at about 22-23psi. I then took the plate off and made another pass, 10.76 with identical 60' as before. This was the slowest pass of the day by .11 of a second.
Test #3 The GSCA "Buick Grans Sport Clup of America" did back to back tests at the 2002 GSNationals in bowling green KY. Their test neted a 2 tenth reduction in E.T. and a 2MPH increase in 1/4 mi times. This was without increasing the boost pressure. How you say? The test vehicle was experiencing slight knock without the plate, once the plate was installed the knock retard was gone and thus netted the 1/4 mi results.
Also
Plenum flow charts comparison each cylinder to average of all cylinders for that plenum.
Stock Plenum
1 -40% 2 -81%
3 +24% 4 -33%
5 +68% 6 +63%
Flow Range; 149%
Stock plenum with AD Power Plate-S
1 -5% 2 -2%
3 +5% 4 +4%
5 -5% 6 +2%
Flow Range; 10%
look at the equality of flow per ea. cylinder
Q1.That thing looks restrictive,is it?
ANS1 When searching for restrictions, you must first look at the most restrictive piece in a system. When it comes to our turbo buicks the most restrictive piece is the throttle body. The Power Plate by itself out flows even the huge 70mm throttle bodies by 50%.With the stock plenum the Power Plate utalizes all of the ports instead of trying to force most of the charge through the back two ports . Because of this, total airflow through the manifold is actually increased !!
Here are some solid flow percentages.
The stock plenum and t.b without a power plate as a baseline.
Stock tb. 100%
Stock tb. with ADPPs plate 100-102%
Precision plenum with 70mm t.b. 123%
Precision plenum with 70mm + ADPPp plate 120%
Kenny Bell plenum with 70mm t.b. 125%
Kenny Bell plenum with 70mm + ADPPk plate 111%
Hemco Plenum with 70mm tb 113%
