BlackBettie6
boost addict
- Nov 23, 2007
i have a 87 gn , TH350,maf trans,hot wire kit , ect. (bought with alot of aftermarket parts already on shes like fraankenstien on crack) trans new to TBs , but have helped friends for a few years. ive heard these engines are quite fragile so i realy need help. when i start my car in the morn.(cold here) the idle shoots up to 2 somtimes 3 grand, finaly settling at about 1000rpm(even in gear). once the engine is at operating temp, the idle tries to drop lower but just surges between 975-1500rpm. also when i drive it the rpms kinda spike (mabey 100-200 at a time repeatedly). when i hit the brake hard from low speeds 50-20 ,30-10, it feels like its going to stall. i was able to get at a Genisis scan computer,i am usein the otc mode and monitoring sensors (to set IAC.TPS), and here`s where i need experiance....
AT IDLE-------(used ALOT of throttle body cleaner, no vac leaks)
Prom ID 4293
O2 cross ---1-8
O2 volts were 14-81 never calming
tps .37 (after attept to set)
IAC .81
Knock NO SIGNAL! (everythings hooked up behind coil)!!
Intergrator 125-130....
BLM 107....
SPARK ADVANCE 34-36 degrees!!! (wow)
LV8 33....
MAF 006
Diag. state 8 ALCL?
Can Somebody please point me in the right Direction befor i put a cheby 350 in it!!!!! i dont wanna hurt her! thanks
Prom ID 4293
O2 cross ---1-8
IAC .81
BLM 107....
LV8 33....
MAF 006
Diag. state 8 ALCL?
