I have done a lot to my GN, and now I just got Turbolink and I want to tune it. I need a little help getting started.
My mods can be found here:
http://personal.mia.bellsouth.net/mia/s/h/shawnco/gn.html
How do these numbers look:
IDLE:
IAC index 35 # 13 %
LV8 (Load).... 49 #
TPS volts..... 0.46 V
Integrator.... 121 #
O2 volts...... 636 mV
Mass Air Flow. 7 GPS
Block Learn... 109 #
O2 delta cnts. --- #
MAP/Boost....14.0 INHG
WOT:
IAC index 68 # 26 %
LV8 (Load).... 255 #
TPS volts..... 4.56 V
Integrator.... 128 #
O2 volts...... 707 mV
Mass Air Flow. 195 GPS
Block Learn... 128 #
O2 delta cnts. 0 #
MAP/Boost.... 8.0 INHG
I am getting a lot of knock during WOT runs in the lower gears, and REALLY REALLY A LOT of knock during WOT runs in overdrive on high speed cruises on the freeway (moving it from 75-100mph)
TIA
IDLE:
IAC index 35 # 13 %
LV8 (Load).... 49 #
WOT:
IAC index 68 # 26 %
O2 delta cnts. 0 #
TIA
