My two step and transbrake are activated when I ground the activation switch. I want the Nitrous to engage when I open that circuit which cuts off the two steps low rpm cutoff and disengages the trans brake.
I'm thinking I could use a normally closed relay and wire it into that circuit. Then the nitrous would be always hot (while armed and the throttle switch was WOT). Then the circuit goes open, the relay closes and starts the nitrous flow. Only problem is then I have to arm the nitrous after the burnout, which is pretty minor though.
Any better thoughts?
